Requesting pictures of Transmission Equipment
Michaelman Offline
Hi guys, I know this isn't exactly the place but I needed some pictures of the transmission cross member on a 84-87 Turbo Coupe with the Borg Warner 5-speed. I got the motor and transmission from a friend and I'm swapping them into my 74 Pinto Wagon but I'm confused on if the one bolt coming out of the transmission mount is really all that bolts into the cross member, feel like there's something I'm missing.
Any help appreciated, thanks!
Well I don't have a pic handy of my cross member, but this website sells new transmission mounts and it only has one bolt mounting to the cross member. Scroll down a bit to see his transmission mounts. https://tbirdcougarparts.com/#!/
Michaelman likes this post
Michaelman Offline
(11-24-2020, 12:12 PM)Kuch Wrote: Well I don't have a pic handy of my cross member, but this website sells new transmission mounts and it only has one bolt mounting to the cross member. Scroll down a bit to see his transmission mounts. https://tbirdcougarparts.com/#!/
Thanks! Strange system as most other cross members take two bolts.
V6TBird87 Offline
You can remove the aluminum adapter that the trans mount bolts to, and then use a fox mustang style mount that uses the two bolts that you're used to seeing.
The single bolt style mount is specific to the Tbird/Cougar platform. The factory mounts were fluid filled for vibration damping.
2018 Mustang GT
1988 Turbo Coupe, 5-speed
aka Tbird232ci
