Replacing timing belt
TeamEntity Offline
Dont' have the manual yet. and since i'll be in there. any mod recommendations?? thanks..
Honest and sincere.. NO B.S. From me.
If you got a lot of miles you may want to replace the belt tensioner. You could put on an adjustable cam sprocket but if you got a stock cam it may not be worth it. If you got an original water pump, you might want to replace that
http://www.turbotbird.com/techinfo/CamTi...Timing.htm
[This message has been edited by Pete D (edited 02-04-2005).]
tlswart Offline
Best to go ahead and replace rubber hoses in the area and the thermostat.
Terry: 88TC, 5spd, Gillis valve. NATO Member
tps87turbo Offline
Shaft Seals for the Crank, Aux Shaft & Cam. Also Tensioner, & Water pump as stated eariler. Hoses, Belts & Thermostat are also good candidates.
Tony Sceia -
Tony Sceia -
HIS Red 88 TC
