Replacing PRC Strut Mounts - 87 TC
vegas_ss Offline
After searching, I found that some have replaced the strut mounts without any problems. There was some discussion about needing to use a washer or two for the PRC actuator to mount up.
Is this a certain brand of strut mount that required the washers or do all replacements need them? Any recommendations on which ones to use?
Also... do the MM caster/camber plates work with the PRC strut? I thought I read that it doesn't on the MM site, but can't find that info and haven't come across anyone using them with the PRC's.
1996 Impala SS
vegas_ss Offline
Anyone?
1996 Impala SS
http://natomessageboard.com/ultimatebb.p...173#000000
speaks to Moog
Moog again:
http://natomessageboard.com/ultimatebb.p...974#000000
MM CC plates & prc
http://natomessageboard.com/ultimatebb.p...456#000000
vegas_ss Offline
Thanks... I'm picking up the strut mounts from NAPA tomorrow... I asked them who made them and he said either dana or perfect circle, so I'll check them out. I was pretty sure the MM CC plates wouldn't work, but couldn't find the reference... Thanks again!
1996 Impala SS
