replaced fuel pump, car still bogs - car runs lean too
r3lic76 Offline
well i replaced the fuel pump and put on a BBK 255 (same as walbro 255) and it isn't the high pressure one
at around 10psi on my T3, the car starts to bog....kinda feels like maybee the knock sensor is retarding timing or something
running car test shows codes 25, 41, and 73 (and possibly 21 but it only gave that once)
41 is "system lean", 25 is "ks sensor not detected" and 73 is "insufficient TP output change during test"
what do those codes mean?
could it be my spark plugs? i just changed them and i didn't set any gaps
88 Turbocoupe - T3 conversion - bbk255 - kirban FPR - open 3" dp - ported lower intake
r3lic76 Offline
ok i suppose "ks sensor not detected" is because i didn't tap on the car to activate the knock sensor
what does TP output change mean?
r3lic76 Offline
because my car is running lean, im thinking i need a new FPR because I have a T3 turbo, 3" DP, ported lower intake
another thing, im running with an open 3" downtube (its the short 3" dp from sac mustang)....this shouldn't cause a lean condition because if the O2 sensor was picking up extra air, the car runs rich
i put in copper spark plugs but didn't set a gap, didn't someone say that their car bogged because of this?
thanks
natmac3 Offline
First off, gap the plugs to spec, although I don't think that's the problem.
I'd bet money that all you need is a new TPS, becasue the code's showing insufficient TP voltage change during the test, and if it was malfunctioning, the EEC wouldn't be able to properly add fuel, so the EEC is seeing less voltage than it should at a given throttle opening, and dumping less fuel than it should, hence the leaning, KS hearing a ping and cutting timing, there's your bogging... There's my .02
Check the TPS with a voltmeter and get back to me...
1987tc
Kev Offline
Good call natmac.
Kev
1988 TC 5spd
If you didn't quicky open and ckose the throttle to near WOT during the test, then you get the code 73. Test the TPS per the article in the Tech Section before replacing it.
It sounds like you need to run the fuel system diagnositcs. I can send them to you in a few days when I get home. Send me an e-mail if you want them.
Ales Offline
I would definitely like to have this diagnostics too, I think my fuel pressure regulator its not working right [Image: frown.gif], i will drop you an email.
r3lic76 Offline
yea you already sent them to me a week or two ago Pete, thanks but I dont have a fuel pressure regulator (it's $40 for a new one)
r3lic76 Offline
err i mean i dont have a fuel pressure guage
You REALLY need to get a fuel pressure gauge to diagnose the problem!
