I bought an A-pillar with a 2 gauge pod mounted to it. The person that I bought from painted it gray. I'd like to strip the paint from it, but I am scared that regular paint thinner would hurt the plastic.
Could someone tell what to use to strip the paint and where to get it?
Thanks,
-Kashain
Thanks,
-Kashain
88 TC
HY 35, Ported Oval head w/OS valves, EEC Tuner, Bob's MOAL, .510 lift cam, Tial 38mm wastegate, K&N in fender, Kirban AFPR, Walbro 255lph fuel pump, 57 lb inj., GN intercooler, Gillis valve, Race eng. adjustable cam pulley, HKS SSQV BOV, Steeda Tri-ax shifter, 4" DP to 2 1/2" exhaust, no muffers, Timing set to 12* BTDC, 26 psi of boost. Needs to get tuned!
Proud to be a NATO member!
