Removing LA2..?
23027 Offline
How the heck do I get the LA2 out of there.. It is absolutely surrounded with.. Stuff
Any tutorials on how to do this right? Or is it supposed to be this difficult.
87 Turbo Coupe
Half-Pint Offline
not that hard just get a 10 mm socket and loosen up the mount enough to twist the comp. out a little then use the socket to loosen up the bolt in the middle of harness. once you get the bolt loose all the way the harness will separate easily from the comp.No problem Wink
87T/C,K&N cone on VAM,255lph,Kirban@42psi,Hallman@16psi stock IHI,R.R. in but going out in favor of the stocker,aluminum driveshaft,tranny weights gone. ?whats next?HMM!
23027 Offline
I'm kind of not following.. The only bolt I saw that seemed to hold the la3 in was in the middle of the harness, and when I tried to loosen it it seemed to get tighter, both directions.
87 Turbo Coupe
teal95 Offline
Keep loosening it. If you watch closely it will be slack for a couple of turns and then tighten up again. When it is tightened up it is pulling the connector out of the EEC. All of those pins make for a fair bit of tension to pull it out.
steve
'83 & '84 GT turbo EEC-Tuner
'85.5 & '86 SVO twEECer
2x '87 & '88 TC QuarterHorse
'93 LX 5.0 notch Moates chips
3x '95 & '96 GT
viney266 Offline
Thats to get the connector off. Its tight, and then 10mm bolt has to be turned quite a few times. Then there is a small 7mm nut at the bottom right of the computer that holds the white strap over it. I took this bolt out and it gave me some more room. Then just wiggle and pull the wires out of the way. Its tight, but It will come.
Speed is only a matter of money, How fast do you want to go?
CougarXR7 Offline
It's a blast putting it back in, too.
Smile
1986 Mercury Cougar XR-7
5-Speed - Leather - Dual Manual Seats - Vent Windows - Smokin' T3
23027 Offline
Great.
I think I'll wait until its warm out to do this.
Thanks guys
87 Turbo Coupe
