Relocating Battery to Trunk
Noname
Guest
Has anybody done this?
I am thinking about it and wanted opinions.
What are the pros and cons to this?
Pics if you got em!
James Westerfield
88: Densecharger cold air kit w/ K&N, polished upper from Dan E, Gillis Boost valve,4 point roll cage w/ Corbeau seats.
Black Exterior W/ Raven Interior 190,000 Miles
Gary S Offline
My first question would be why would you want to do this unless you are concerned with weight transfer upon hard acceleration.
I haven't done this with a TC but I did do it with a 1965 Shelby Mustang Clone. Wasn't a problem. Just went to the boat store and got me a plastic battery box to put the battery in and drilled two holes in the trunk floor. I mounted that one over the right rear tire but that may be a problem with the TC since the shelf in that area is narrow. In the middle you have the spare to contend with. I used heavy duty welding cable for the cable and soldered on some terminal ends. Make sure you use insulated cable hangars when attaching the cables to the frame as you run the cable to the front of the car.
Gary S
1987 Turbocoupe
168,000 Miles
5 Speed
Black w/Raven Interior
http://www.turbotbird.com/showroom/data_...t_87tc.php
TCKen Offline
If you really want to relocate your battery to the trunk and make it legal for sanctioned racing, check out this site (www.madelectrical.com) and possibly call Mark Hamilton, the owner of Mad Electric. Sanctioning bodies require a rear-accessible battery disconnect switch to shut down the entire electrical system. However, disconnecting the battery while the engine is running will fry your EEC and possibly the alternator. I used the Mad Electric rear-mount battery kit which also relocates the starter solenoid to the trunk and replaces the underhood solenoid with a stud terminal. I used a Flaming River pushrod-style disconnect switch mounted next to the trunk latch support with the pushrod extending out at the upper right hand corner of the license plate. Run a 8 gauge wire from the battery + to the stud terminal to maintain the battery connection when the disconnect is opened. I ran two 8 gauge wires from the load side of the disconnect to EVTM connections S267 and S268 to shutdown things when the switch is opened. Hope this helps.
88TC, 90K miles, Gillis valve, K&N cone on VAM, MSD ignition box, coil, and plug wires, Hurst Mustang T5 shifter, 2 1/2" cat-back duals, trunk battery with disconnect, seguential taillights, more to come.
Ken Humphrey
88TC, Black/Raven, FMIC, 130 amp alternator, MSD ignition, 40Bob manifold with 3" downpipe and Magnaflow 2 1/2" duals, trunk battery with disconnect, CHE rear control arms, Koni Sport shocks, MM front coil-overs and caster/camber plates.
JamesW Offline
My goal is to keep the car as a daily driver with weekend runs at the local strip.
Is there any problems with the battery being so far away from the alt?
If I move the battery to the trunk I think it would be the ideal place to put my MSD when I get it.
James Westerfield
88: Black Exterior Raven Interior,190,000 Miles
Gillis Valve, Densacharger Cold Air Kit W/K&N
James Westerfield
88: Black Exterior Raven Interior,196,000 Miles, 5 speed,
Gillis Valve, Densacharger Cold Air Kit W/K&N in fender well, Polished upper from Dan E. 4 point cage, black cloth Corbeau seats
(wish I had sprung for the leather ones) 5 point Grant harness.
2001 300M W/90xxx,
1998 Windstar 168xxx gotta drive the kids around
91 Ranger 2.3 W/275,xxx Just an beater to drive to work
Jim
JamesW Offline
I never thought of putting it there. Thanks for the idea Pete!
James Westerfield
2001 300M W/90xxx,
cbpldc Offline
Sweet. That would make more crap that I have hanging out in front of the car. Sweet place for it, though.
That would sit right above my intercooler.
Chris
Blue 87 T/C, basically stock and slow.
Black 85 T/C. The race car.
