My ABS doesn't work and I don't really care to fix it to be honest so should I just order stuff for a fox body mustang? But I will need rotors eventually and pads up front. I was wondering where or what brand rotors/pads/brake lines do you guys recommend? Slotted would be cool but not really sweating it. I didn't know if it would be cheaper for the Fox vs the Turbo Coupe.
88 5 speed TC
Cant help much with the brake stuff, but I know a friend of mines slotted and drilled rotors are completely unnoticeable with the snowflakes on.
gadgetolds Wrote:Cant help much with the brake stuff, but I know a friend of mines slotted and drilled rotors are completely unnoticeable with the snowflakes on. I've got cobra rs but even still it's a a lot more money for slotted than I won't bother.
88 5 speed TC
Gage,
Do you still need a adjustable fuel pressure regulator? I have a bbk rail mount but it needs a rebuild. Bbk does offer a rebuild kit for them you just have to call and ask. I wanted $20 plus shipping if your interested. I would have pmed you it your box is full.
88 5 speed TC
