(This post was last modified: 05-21-2021, 06:43 PM by acroft11. Edit Reason: Found some INFO )
Hey guys,
I am new to the group, but not to the car. Long history short, have owned 5 87-88 TC's over the past 25 years. Also with a few Supercoupes in the mix.
My latest is a '88 5 speed that I bought 5 years ago. Pretty much drove it home and parked it. Finally getting around to some much needed TLC. I was just going to replace some heater hoses so that I could drive it again. Well...
I have torn it down and the head is about to come off. Now planning to just pull the engine to easily replace oil pan gasket and get at the leaky rack and pinion/entire power steering system fixed.
My main question is, if I am planning to keep the factory IC on top, what is the most HP gain I can get. If that is my plan, what's worth doing and not doing? Should I really beef up the bottom end while it's out? Or just have machine shop check it out and fix what needs fixing?
The easy to get to stuff I'm not really worried about, I can always change that later.
Not a daily, but want it to stay reliable and just a fun weekend car.
Things I already purchased/planning
Oil Pump
timing belt
all gaskets (obviously)
All new water lines, pump, thermostat, radiator
plugs, wires, cap, rotor, coil
I got the XS-Power tube header. Didn't realize it was china, so might be changing my mind, but it came in and seems pretty nice?
Stinger 3" exhaust turbo back with magnaflow, no cat right now?
Stinger Oil Lines
EGR delete?
Remove Factory AirBox
Clutch Kit, Just got an OE replacement, but thinking I might have gotten something a little better?
Not at the moment but soon
Walbro 255 and filter
I know most of this is covered in the thousands of post on here. So I guess what I am asking is how restrictive is the Factory IC and if I don't want to do a FMIC, do I really need to worry about engine internals? Probably will never replace the ECU, but I guess I should never say never.
Is a bo cam 1.5 worth it? Should I port the intake?
I've read the T3 with A/R .48 is comparable to the IHI, with some improvement, but I assume this would need to have FMIC to be worth it?
Sorry for the long post, I know I am a little all over the place.
***** EDIT **** Actually I stumbled across the stinger FAQ and think I got most of my answers. But I'll still take any input you guys have.
Thanks in advance for any advice.
Adam
Oil Pump
timing belt
Stinger Oil Lines
EGR delete?
Adam
