Rear Window Trim on a 88 TC
Viper7 Offline
My TC has a rubber trim piece that surrounds the entire rear window. As with many the rubber is shot. I purchased a trim set off Ebay that is supposely for an 88 T-Bird TC however it is steel and came in several pieces. I guess my question is did I purchase the right part? And, is there any special mounting I'll need to do? As always thanks in advance.
Viper
88 TC Project Car|Deep Ocean Blue Metallic|Marchal Fog Lights|Custom Interior|Custom Instrument Panel|Gillis Valve|Cone Air Filter
Shine she may, Run she must
longbedGTs Offline
I've seen the same advertised for an 88, but I don't think the 87-88s came with metal trim. The earlier birds did. The 88 trim consists of a plastic like piece that goes around the perimeter of the glass and has a little channel that allows the other trim piece to "snap" into it. So...the 88 trim consists of 2 pieces, one of which you won't see once te other piece is installed.
88 TC 5spd~money pit
88 TC 5spd~78K miles
vinnietbird Offline
My '88 has the metal trim pieces for the rear window. My last two '88s had the one piece plastic trim that snapped into a channel in the window. I see them from time to time on Ebay.
The switch from metal to rubber was made early in the 88 model year.
Viper7 Offline
Any ideas how to get the metal ones on to replace the rubber.
Viper
boboli Offline
You cannot use the metal ones if your car never had them without adding the attachment pins to the body of the car. The amount of work to do this would be way more than the cost to take your car to a glass shop and have them install a universal window trim seal. They have to take the glass out and then install the seal around the glass edge. Then reinstall the window. I was quoted $70 to do this but have not had time to take my car in
turbo80sdriver Offline
The build month of one of my '88s is January and it has the original metal rear window trim. The other '88 build month was March, so that narrows down the time frame of change-over a little bit.
'88 TC-Black T-5 with 79K stock 98.5% original, just w-i-d-e rims and tires, and some under hood powder-coating
'88 TC-Blue w/98K. Stocker w/t-5 ( the resurrection car) top gas mileage =31 mpg!
'88 TC-Grey w/99k. Auto, well optioned, 2nd owner car - getting more options
'87 TC-Blue w/123k t-5 parts car - less of a car now
'88 TC gray- body only so far- very very late factory build dated car, awaiting resurrection
'87 GN w/16.8K
"96 Bronco XLT w/351 (5.8l)
BirdJunkie Offline
My 88 was built 12/87 and it has the rubber trim.
88 TC 5SPD BLACK MY BABY ORIG.OWNER(garage queen)/06 GTO 6SPD RED WIFES CAR(cop magnet...lol)/2011 TAHOE WHITE (wifes daily driver a.k.a Fifty Cent)/2016 SUPER DUTY RED(my daily driver a.k.a BIG red)/06 HAYABUSA (SEXY BITCH)..STATEFARM LUVS ME. ----N.A.T.O Bad Boy Division President----
turbird77 Offline
I'm going through this now while painting mine, and am seriously considering switching to the metal trim. Should be easy to tack weld those studs on, since my rear window is out right now.
88 TC - Work in Progress.
vinnietbird Offline
http://www.ebay.com/itm/380718049744?ssP...1423.l2649
