Rear main seal depth
87TurboBobby Offline
Allright I have searched extensively,
What is the correct depth to install a rear main seal on an 87 TC. Should it be flush with block or deeper?
Thanks in advance,
Bobby
90 Mustang GT Vert.
95 Mustang Vert
04 F150 Heritage
92 Chevy Silverado
tps87turbo Offline
It should be flush, but if you have a groove in you crank from wear, then you can set it back a liitle so that the seal rides behind the groove. A little Back, not alot because it will be a bear to remove.
Tony Sceia -
HIS Red 88 TC
Yep, book says it must be within 0.005" of the rear face of the block
Thanks Tony and Pete,
This brings on another question,is there a double lip seal that will fit the TC? Anyone around my town that sells parts doesn't show one, for the TC or 5.0 Mustang or anything. The few that thought they had one wasn't a double lip. This includes Napa,Autozone,Advance and a local.
THANKS
90 Mustang GT Vert.
95 Mustang Vert
04 F150 Heritage
92 Chevy Silverado
gregpro50 Offline
Get the Fel-Pro teflon seal. You usually have to order it since its not carried in parts stores. Its like $25 or so. Its pretty stiff and can be difficult to get on. Just make sure to put it on DRY.
'79 Indy pace car T-top
'81 Cobra
'81 Cobra T-top
'82 GT T-top
'85 ascMcLaren coupe
'86 SVO
'98 Lincoln Mark VIII LSC
I was recently told there is an "offset" seal.
I don't know anything about a double lip seal for our engines.
gregpro50 Offline
Also, if you do have a groove in the crank then you can get a sleeve kit for it. The problem is that if you do that it is not recommended to use a teflon seal.
'81 Cobra
'81 Cobra T-top
'82 GT T-top
'86 SVO
tps87turbo Offline
The Offset Seal I think is sold by Race Engineering or Racer Walsh. Look in the vendors section under their websites & search for Rear Main Seal.
Tony Sceia -
HIS Red 88 TC
