A bad ground at the defroster will not cause a excessive load on the alt.... if the ground is bad, the defroster will not draw any current. The ground is not your problem.
The rear defrost draws a fair amt. of curent... a little over 10 amps if memory serves me. THis, along with lights does put extra load on the alt. When alts whine under load, they are in the early stages of failure.
