dpdisxr4ti
Jun 2001
New York
I'm having a problem getting the piston retracted back down into the bore. It extended easily enough by turning it counter-clockwise with a pair of needle nose pliers, but turning it clockwise does not seem to be running it back down the hole. Using a brake pad seperater was a futile effort - the plate on the tool started to bend.
Suggestions?
Thanks,
Brad
Brad
cnpowell
Nottingham, MD
If I remember correctly, I had to open the bleed screw. I, guess, the piston builds up pressure when you try to turn it back in. I hope this helps.
Carl
Carl (cnpowell)
dpdisxr4ti
Jun 2001
New York
Carl
Thanks Carl, I'll give that a try.
Brad
Brad
TCx2
Sierra Vista, Arizona
I JUST did this last nite. <G> Open the bleed screw...
You wil have to bleed the system if you do this, so have some brake fluid on hand but other than that, it is THE way to do it.
Also, best way I saw to screw them in was, pull the rotor off the axle. Then bolt the
support bracket and caliper to the axle like
it normally goes. (No pads)
Bolts only have to be finger tight.
This holds everything so you can use two hands and apply some pressure to the caliper
and needle nose pliers. We had two of us working on it so I held the caliper from sliding too far on the slider pins, while my partner ran the needle nose pliers. He put the pliers in the slots, then put a small breaker bar between the handles on the pliers to get leverage. It still took some work.
Kevin
TCx2
88 White TC, 5spd, Loaded
88 Black TC, 5spd, Base
87 LtBlue TC, 5spd,Loaded
Kevin
TCx2
dpdisxr4ti
Jun 2001
New York
Great, now I feel better that two of you have said the same thing - thanks for the details...
Brad
Brad
cnpowell
Nottingham, MD
I picked up an attachment tool that fits into the slots on the piston from one of the auto parts stores .... I don't remember which one or the cost. It makes it a lot easier than using pliers and you might save a knuckle or two!!!!
Carl
Carl (cnpowell)
1987tc
Bicknell Indiana USA
Carl
I know at Advance where I work we have it for $3.00 or $4.00 . Worth it at twice the price to avoid the frustration!
Wes
1987 TC:
Hurst compition plus shifter,K&N cone,roller cam,custom single exhaust,Gillis valve,H&R springs,KYB shocks,struts and quads.
3.73 rear.
Tubular rear control arms and Kenny Brown trac kit brackets. soon to come, Installation of Caster camber plates and a custom built roll cage.
Wes Arnett
Linton Indiana
dpdisxr4ti
Jun 2001
New York
Thanks guys, this worked out perfectly by putting a hose on the bleeder and cracking it open a bit. The piston easily screwed in at that point, just using a pair of needle nose pliers. But certainly, the proper tool would have made the job even easier.
Thanks again,
Brad
Brad
