Major issue with the passenger side rear brake. The bird needed brakes in the back so off I went to repair and rebuild. Everything went fine up until I went to loosen the top caliper bracket bolt. The son-of-a-bitch will just not loosen. I've used PB Blaster a breaker bar and have had nothing in return other than a very close to stripped bolt. Does anyone have any clue on a way to loosen a siezed bolt? I'm down to vice grips on this piece of shit, and I'm way past the point of frustration.
I've ordered a new right hand bracket and pin kit from ford (right hand is the passenger side right?) so short of me cutting the f*cker off, I'm up for ideas.
Thanks,
-John
88redbird
Jan 2003
vancover B.C
just a quick thought if u can get the hole assembly off the car why not try soaking it in the penitrating oil and see if u get it off that way befor u shell out money for new parts
Rebel72903
Dec 2002
Fort Smith,Ar.72903
OMG...John...you sound like me dude...I can HEAR me saying that. I am soooo glad that I am not the only one to have those kind of days. Sorry for the troubles dude....good luck.
86 T/C black with red leather interior,tinted windows,5 spd,3" exhaust,
dynomax dumped at the axle,lots of mods planned,gonna be a heck of a ride,hang on
turbocharged1
Dec 2002
E-town, Ky, 42701
you may want to try heating it with a torch, that's how I got the nuts loose on the old turbo. Might work on the caliper, just be sure not to get the caliper too hot.
87 TurboCoupe, 5 speed, Garrett T-3, K&N cone filter. New rotors all around, new brake lines all around..
Turboy
Oct 2001
Roseville, CA USA
Sounds like you're describing the bracket that holds the caliper? Ditto on the torch. Also, once you get the bolt hot (this might be tough to do since it is on the backside) take a 2 lb hammer and rap the bolt head really hard a few times - this will help to break it loose. Only had a few times that this method did not work.
1988 TC 5 spd K & N, Bleeder. Next up - 3" downpipe to 2.5" duals
