I have had the '86TC on jackstands for nearly three years now. The car is being completely rebuilt mechanically and heavily modded.
I have SN95 front hubs 13" rotors and have built adapters to use 05-09 mustang calipers (because you can buy new takeoffs for near nothing on ebay).
Now here is the issue I am having I need a 11-12"dia x 1" thick rotor for the rear, that will fit over the axle flange. SN95 fronts will not works as the inner dia. is too small. Does anyone know of a rotor that will work? Offset of the rotor is not a big issue as I will need to build caliper brackets for the rear also.
For those with questions about my brake setup, i plan on doing a in depth tech article with pics when I am done with the project. That I will post here.
86TC Saved from certain death
88TC Gave its life so other TCs could live.
88TC DD.
88TC DD.
