Huey866
Jun 2003
Catlettsburg, KY
Is there anyway to check the bearings in the rear axle without taking out the axles? The reason im asking is because I have a noise coming from the rear of the car, with new shocks and good tires, all that is left is the bearings and rearend. Huey
87 Turbo coupe, 5spd, full factory options, custom cerosion coated exhaust, Gillis valve, bent frame.
87 TurboCoupe - silver, 137k, 5-speed, 3.73, 5 lug swap, MM... Evertything, 03 Cobra Brakes, Griggs Subframe connectors, Bo 1.5, Big Valves, massaged 79 turbo head, Essy Cam Gear, Boblog + Elbow, .63 T-3, Stinger Exhaust/FMIC
You could put it on a chassis lift, raise it a little then run it in gear and listen
That always works for me. Be sure car in on jack stands, not just a jack. The bad axle bearings seem to sing even louder with the bearings mostly unloaded with the rear hanging up in the air. I have found that you need to run thru a range of speeds to listen for different noises.
