Hello
I need to get rear axles for my '84 TC. My mechanic says they are not available. Any ideas?
Thank you!!
I had a failed rear axle bearing chew up an axle in my 86 Tbird 5.0 probably 20 or so years ago. Had new axles (I replaced both sides) made for me by Moser Engineering. They had the specs for the axles in their database. I forget the total cost, but I seem to remember around $100 or so per axle (cost from 20+ years ago). for the axles and new bearings.
If by some chance Moser doesnt have the specs anymore, etc. I am pretty sure you can send them one of your axles and they can make an replacement for you.
Excellent, this was spot on - they didn't have the specs but could replicate the original--again thanks!
No problem! Happy to help you get your TC back on the road!!
