85Original
Jan 2004
Fallon, Nevada, US
I'm getting ready to swap an 88 8.8 rear end with 3.73's. I placed my 15" 10 hole wheels on ahead of time to check caliper clearance before proceeding. What I found was that the lugs are shorter, so I'll need to get longer ones, but I also found that my wheels aren't setting on the hub ring, because the 15" wheels are beveled on the back of the hole and the axle hubs don't project out as far as the hubs on the axles with drums on my 7.5" rear end.
Am I right? Has anyone else used 15" 10 holes on 8.8 axles and rotors? Eventually I will go to a bigger wheel, but not yet, unless......
R. Libby
85.5 Med. Regatta Blue TC
russ c
Nov 2005
Mt. Olive,NC
I can check mine tomarrow night and let you know what I see on mine. I have a rear and ten hole out in the shop.
86TC Saved from certain death
88TC Gave its life so other TCs could live.
88TC DD.
86XR7auto
Mar 2003
Mt. Pleasant, MI. USA
I have seen 10 holers on 87-88TC. There is one forsale in Michigan with that combo. I would assume the rear end is still original. It should work.
Travis
Walsted
Fort Worth, TX
I used 87 axles and an 83 drum set up with my ten-holes on an 8.8 from 87.
85Original
Jan 2004
Fallon, Nevada, US
Did any of the above responders find that their lug bolts too short for the 10 holers? Thanks.
R. Libby
Walsted
Fort Worth, TX
86XR7auto
Mar 2003
Couple of years ago I had my 235/60-15 BFG drag radials on a pair of turbine wheels. The stock lug nuts that came with the car where not long enough to bolt the turbines on. I got longer LN not been a problem sense.
Travis
sbhjr44
Jul 2005
Arlington.Ma. USA
My 87 came with 15" ten holers and the lugs are the same size as the ones on my 88.
Stinger dual3"exhaust from dp & cat to magnaflows w/2.5 outlets w/tailpipes.Homemade CAI w/boost at18psi.MM c/c plates and tubular lca/front coilovers with Koni red adjustables all around. Ported/BV head/A237 and bobslog w/a stinger fmic set-up waiting to go on.86 stang gt w/motor and T-5 from a 86 TC w/3"SS dualexhaust w/cc plates and lowered 1.5".With volvo ic installed.
russ c
Nov 2005
Mt. Olive,NC
The studs on my rear do look a bitt short for peace of mind to me. I would install a wheel and make sure I had a full nut on the threaded portion of the stud. Any less and most states won't let it pass safety inspection.
88TC DD.
