UglyBird85
Jan 2009
Norfolk, Va
tryin to get this done while its still light out. I just picked up some motorcraft platinum plugs and according to the gapper i have its set at about .054. I've read that it should be at the most .032. should i just leave them like they are? or push em down or whatever you do to make it the gap smaller? I'm running about 14psi. Thanks
---Justin
87 Burgundy TC 5spd. K&N Cone filter-Walboro 255HP-.60/.63 Garret T3-Gillis @ 18psi.
SHELF: NPR FMIC-Ford Racing 42# injectors-Tripminder-
UglyBird85
Jan 2009
Norfolk, Va
and should i have bought 87-88 spark plugs since i did the computer swap??
---Justin
You should return them, get copper plugs and gap those to .032
I ran some Autolite plats, but others have had problem with platinum plugs
YMMV
UglyBird85
Jan 2009
Norfolk, Va
so should i set these to .032 for the time being? nd do i just push the top down or something to close the gap??
---Justin
zbird
Jul 2008
Joshua, Texas
You Just tap them down to set gap or bend them using the proper gap tool. Just dont break them off.
