Reading codes
1988turbotbird Offline
I did the jumper wire with (key on engine off)from the EEC test connector to the STI connector turned the key on and watched the CEL blink and got:
8 blinks-3 second pause-8 blinks
Then 10 seconds later:
One blink-5 second pause-One blink-2 second pause-One blink
Then 5 seconds later:
and that was it. Is there a decoder on the FAQ page or somewhere so I can figure out what these mean? I hope this is my problem all along...
Kev Offline
http://www.turbotbird.com/techinfo/eec.htm
Kev
1988 TC 5spd
thanks im not awake today lol...is the "service codes" the number of blinks?
Kev Offline
No problem! Good luck!
Kev
1988 TC 5spd
I just did the key on engine on the idle kicked up to 3 grand,and slowly lowered its self and stuff..stupid question, do you add up the blinks and the total in the given sequence is the service code?
Kev Offline
http://www.turbotbird.com/techinfo/Retri..._codes.htm
Look here under where it says "Running the KOEO test". It describes how to read the codes better than I could tell you.
Kev
1988 TC 5spd
thanks again gonna go redo it now
