Gary S
Burlington, KY
Ok, going to throw this one out to you to try and get some opinions. I have a rattling noise upon acceleration. I cannot pinpoint where it is coming from but is definitely loud. It also seems to get louder as the car warms up. There is no noise at idle or no noise if you rev the motor while under the hood but when you drive it, you can hear it very clear on the driver's side but it is hard to tell if it is coming from under the car or from under the hood. It doesn't seem to affect performance any and has been going on now for about 10 months. Any ideas on this would be greatly appreciated.
Gary Schweikert
[email protected]
1987 Turbocoupe
155,000 Miles
5 Speed
Black w/Raven Interior
Gillis Valve
3" Downpipe
Dynomax Super Turbo Mufflers w/21/2" exhaust
Centerforce I Clutch and Pressure Plate
Other than the above, she is "bone stock."
Looking to "upgrade" this winter with some polishing and painting
natmac3
Mar 2002
Aberdeen, MD
Likewise, I have a similar light rattling noise in mine. It's not visibly hurting anyhting, and performance remains consistent.
Just curious. It's not s'posed ta rattle.
1987tc
revamp
May 2002
Norristown, PA
I had a similiar problem like this, couldn't find out where it was. I later found out the IAC valve was loose, behind the throttle. It sounded like it was coming from the dash, but it was under the hood, very close to it. That was just one of my experiences though, sounds just like it.
88 TC W/ 87K:
K&N in custom sanded airbox||Gillis Valve||Stereo Sytem: Pioneer 8400, Infinity Ref. Series & Polk Audio Speakers Powered by 4 Channel Pioneer Amps||Performance Radiator & Cooling System||Custom Interior Converion||Gutted Cat & Dynamax Ultra Flow Muffler||Indiglo Gauges ||and more to come!
loose cat converter shield?? Lifting eye on the last exhaust manifold stud loose and vibrating on the fire wall??
Dan E
Greensboro, NC
I agree with my esteemed "elder" in his theoretical conclusions for a potential and likely variable that may be the source for your condition [Image: biggrin.gif]
Dan Eaves
Dan Eaves
