David85TC
Sep 2008
ReykjavÃk, Iceland
1985 Turbo coupe 71,000 miles Medium Red Metallic with Gray cloth interior, all option except leather and passenger power seat. All stock. But unfortunatly she has bad rust.
1988 Turbo coupe 88,000 miles Sandalwood with base leather seats, all option except moonroof and passenger power seat. Bone stock.
1985 30th Anniversary T-bird.
tr_guy79
Jan 2004
SE PA (DELCO), USA
Hmmm... Interesting... I wonder what BoPort can massage out of it...
-Shane
jangus
May 2008
Nebraska
I'd like to know how they managed to keep the stock port locations and chambers and still managed to improve coolant flow to reduce blowing headgaskets (usually comes from detonation, not overheating). There's only so much room in the casting, and if they kept everything stock location and enlarged the ports, they have LESS room for coolant flow. What a bunch of crap.
The only reason it runs cooler is because it's ALUMINUM. HELLO.
And the price give is for a bare head. No valvetrain or cam.
88TC 5speed, 160,000+, ranger roller, Evergreen T3, cone filter, manual boost controller.
One parts car still waiting to be taken apart.
Waiting in the garage: SC throttle body, SC intercooler, graphic equalizer, among other things.
dd88T/C
Jun 2009
Tampa, Florida
I can see how the head gasket blowing is prevented. Heat is a cause of detonation. Heat will also cause a cast head to warp, thus causing a gasket to pop. Lower engine temps means less chance of detonation, less chance of warping a head, and less chance of popping a gasket. However, I am not sure about the coolant flow. That ones a mystery.
'88 tc daily driver
.48 t3, stinger fmic, boblog, ebay twin piston BOV, 3" stinger dp, 3" exhaust shop straight pipe to the axle, ported/knifed lower, gutted upper, 3" intake tube & k/n filter, kirban fpr (42 psi), walboro 255, gillis @ 22 psi, pony wheels
shelf:
sn95 tb, rr, zeitronix zt2 wideband, magnaflow muffler/turndown, MAF swap, tune
TurboCoupe50
Chesapeake, Va
Gotta love their write up...
Quote:The Rapido Aluminum replacement cylinder head is not a high flow, high performance, racing cylinder head, although it does flow marginally better than a stock cast-iron cylinder head. Out of the box, it will IMPROVE your vehicles performance by virtue of "better power to weight" and "lower center of gravity". These differences will be immediately noticeable to all but the already "brain dead". Particular attention has been devoted to improved coolant flow to "eliminate the combustion chamber hot spots" the original cast-iron head is famous for. This trait contributes, in large part, to the cast-iron head tendency to blow head gaskets and to develop (and ultimately fail due to) cracking.
Rob..
Nov 2009
Naples, Fl
That head has been around for about a year or so.
I want to live in a world where monkeys don't dig up the dead and parade about in their shoes.
88 7F, SS big valve head, port matched in/ex, gutted and powdercoated intake, A-237, stealth T3/T4 Garrett hybrid, Abaco 85mm mass-air meter conversion, tripminder, Walbro 255 high pressure, SVOJohn tuned.
Ok, who is going to be the first to try it?
TurboCoupe50
Chesapeake, Va
Not me, :eek: I can buy TWO heads with valves for that kind of money... Actually I paid about about $250 less for my Trick Flows, but that was in '99...
I think that head has been out for 3-4 years. I don't think I have heard anybody post here that they are using it??
David85TC
Sep 2008
ReykjavÃk, Iceland
Well how about now? anybody tried it??
