so i did a swap for my 98' ranger. you guys are the authority for 2.3 engine, hence why im here.
so i'm having the infamous stutter issue with my vehicle when it warms up. replaced the whole dizzy, using the old module. with the old dizzy, replacing the module with admittedly cheap modules from the "true tech" like of standard motor products line actually caused a no run issue. so I finally replaced the whole dizzy with the Honk Kong special module I have. it seems to buck and stutter when warming up, then just stops. i can't seem to find vacuum leaks but I have noticed that the ports for pressure relief for the intercooler aren't connected. should I fix that? I also have the random stall issue when cold
