BJL
Williamstown, New Jersey
I am being offered a 1989 Ford Ranger engine. I think its the 2.3l HSC. Is this the roller cam type? It has the daul coil pack igniton with 8 plugs.
I was told it is seized, but i think it would be worth to get the roller cam out, if it is not hurt.
Main question is this the roller cam type and should i get it or just leave it, and can a roller cam seize up?!
Im gettin the head for cheap, i mean cheap.
Sorry for the multiple questions
Brian J Larkin
1988 Turbo Coupe, 5spd
dark blue (shiny shiny!),
glasspacks, no cat
BCS bypassed,
clear corner lenses
http://crazydriver358.5u.com
[This message has been edited by BJL (edited 01-21-2002).]
Brian Larkin
88TC 330,000 miles
Slightly Modified
rv23tc
Dec 2001
Sheffield Lake,Ohio
Crane makes a cam for these cars. that's what i'm going with, just because it is a cam for a turbocharged motor.
14.7 @ 90mph
mods: 260 armstrong xp pump,430gears,86 GN turbo,boost controller,9mm motorsport wires
boost gauge, air/fuel
mods: 260 armstrong xp pump,430gears,,boost controller,FPR,9mm motorsport wires,K&N filter
My notes say 89 and up to 93 Rangers for the RR cam. I would pop the valve cover and look at it given that it is supposedly siezed. Anything could be wrong with it.
It isnt a 2.3 HSC if it was in a Ranger. The 2.3 OHC was used in the Rangers, while the 2.3 HSC (a pushrod motor) was used in the Tempo / Topaz FWD econocrap cars, and a 2.5 HSC was the base motor in the early Taurus. Nothing interchanges between the 2.3 HSC and 2.3 OHC
BJL
o ok, i alwasy see the hsc, i think they use the same ingniton componits, but anywasy i gotta look under the vlave cover now, so i will come back when after i get a llok i take a few pictures and post them
Brian J Larkin
1988 Turbo Coupe 5spd, dark blue and shining like a peice of polished glass.
Brian Larkin
88TC 330,000 miles
Slightly Modified
