Random high idle ?
glenn-tc88 Offline
#11
when it idles high tap tps lightly and if it idles down its tps.  mine did same swapping tps fixed it.
Glenn Dembowski
2003 Mercury Marauder Black
1988 Thunderbird TC Sandalwood 5sp
1974 Harley Davidson FLH
1998 Chevrolet K1500
t c mike Offline
#12
(06-27-2020, 02:16 PM)glenn-tc88 Wrote: when it idles high tap tps lightly and if it idles down its tps.  mine did same swapping tps fixed it.
Thanks Glenn !!! Makes sense to me. Won't get to it till next week & wiil post results then.
Thanks again !
mike
vegas_ss Offline
#13
I get the random high idle occasionally... usually notice it happening after a freeway drive.  I do have a manual so it's not a big issue for me.  Usually shutting off and restarting cures the issue. Other times just driving a bit takes care of it.  I did replace the VAM about a year ago for a different issue, that didn't have any effect on the random high idle as it has been occurring for several years but not often enough for me to remember checking it out.  Getting old I also get forgetful Wink
BJL Offline
Moderator
#14
typical TPS getting a lil wacky. try resetting base TPS setting or buy a new TPS.
Brian Larkin
88TC 330,000 miles
Slightly Modified
t c mike Offline
#15
(06-28-2020, 02:38 AM)BJL Wrote: typical TPS getting a lil wacky. try resetting base TPS setting or buy a new TPS.
Did the reset to .94 v as Jeff K suggested.....helped, but didn't last long. It idled fast when i had the hood up, tapped the tps as suggested & it came right down.My Ford dealer is getting me a new tps.
Thanks EVERYONE !!!!mike
BJL, anasazi4st and Mikey97D like this post
#16
Yeah sadly like so many, this pretty much has to be a Motorcraft part. I had problems with 3rd-party ones as well.
t c mike Offline
#17
Update : new tps installed, voltage @ ,94, iac cleaned w/new gasket. Dual exhaust completed and my Turbo Coupe runs GR8....finally.
Adding duals & non chambered mufflers lets boost come much sooner. Love it. Next will be manual boost control, but won't crank in too much since it has auto trans.
I just want to drive it......
Thanks to all !!!
mike
Perfect88 Offline
#18
Where can I get a new motorcraft IAC for my 88 tc? I would pay good money for one.
