First time posting. 1988 Turbo Coupe auto trans. 47,600 miles. Sometimes it idles @ 2 grand after a drive. AIC has been replaced....any ideas?
This is my 2nd T C . Had an 87 in the mid 90s, dual exhaust & bypassed the waste control. It RAN GR8 for an auto car.
Any thoughts & info greatly appreciated !!!!!
mike
Welcome to NATO, Mike!
Was the new IAC a Motorcraft part or aftermarket junk? Aftermarket IACs are ALL JUNK. Motorcraft are the only ones that work properly.
Check closed throttle TPS voltage. If closed throttle volts are over 1.0 V you will get a hanging high idle. Best to set closed throttle TPS volts to around .94 V.
06-13-2020, 02:00 PM
(06-13-2020, 12:21 PM)Jeff K Wrote: Welcome to NATO, Mike!
Thanks Jeff !! Authentic FORD iac. Will check the tps voltage. Also the car was only driven 1700 miles in 4 years and had a small 700 cca battery that needed a battery tender. Hoping that driving it & having a new 850 cca battery may
solve some issues too. LOVE my car !! Have had a 53 Ford Vic. for several years & had flathead fever.....don't miss it at all.
Have a GR8 day.mike
(06-13-2020, 02:00 PM)t c mike Wrote: (06-13-2020, 12:21 PM)Jeff K Wrote: Welcome to NATO, Mike!
Have a GR8 day.mike
I'll keep an eye on this one as well. Our '88 does this as well and we've yet to finger it out. It'll just start holding the RPM at idle @ around 1700-2100 RPM. It's not doing the auto transmission to many favors. I've got the wife to shut the car off while sitting in reverse or drive with it under load. Otherwise it'll take off like a rocket!
S-
RC Martin
Mar 2006
Colorado
06-13-2020, 11:25 PM
(This post was last modified: 06-16-2020, 04:54 AM by RC Martin.)
I went through this same thing for years and it magically went away though I don't know what one thing cured it. I now have a 2k cold idle that settles down to 900 hot, I call that good and normal. On cold starts sometimes it stumbles and dies, always restarts and never dies again rock solid. *shrug*
Across throwing parts at it, I did new plugs .030, wires,cap, rotor, new cleaned IAC, new TPS dialed in, timing at stock (never ran better for me with some advance), new 195F superstat, EGR delete, new exhaust.
84TBirdTurbo42
Jun 2006
Angola NY
a friend of mine, who has been a Ford tech since beyond the dawn of time, maybe earlier... told me that was the biggest bitch of these cars back in the day. I have a suspicion it might be vam related, as iirc at least on the 86 and older cars, that the intake air temp is measured that way. There are days my car will idle normal, other days its hunting like crazy.
Chris Perry
(06-18-2020, 08:52 PM)84TBirdTurbo42 Wrote: a friend of mine, who has been a Ford tech since beyond the dawn of time, maybe earlier... told me that was the biggest bitch of these cars back in the day. I have a suspicion it might be vam related, as iirc at least on the 86 and older cars, that the intake air temp is measured that way. There are days my car will idle normal, other days its hunting like crazy. THANKS to everyone !!!! 2k rpm has dropped to 1500 and then only once in a while. I too shut it off in gear. Once i shut it down, it doesn't do it again....wierd. It gets serviced next week by an "old time" mech. who knows these cars. He too is thinking tps & iac.....maybe vam.
mike
You can check VAM volts by tapping into the BK/W and W/BK wires at the 4 terminal VAM connector. With throttle closed you want the volts under .5 V. If much above that you can get high idle. You can adjust this by removing the 1/2" or so diameter plug on the top output (to turbo) side of the VAM. Drill a hole maybe 1/4" deep in the plug, screw in a sheet metal screw and pull the plug out using a vise grip on the screw. Use a long Allen wrench (I forget the size..... maybe 3/16" or so) to adjust the bypass air, which in turn changes the closed throttle VAM output volts.
I discovered this years ago when I replaced my VAM and immediately had a high engine hot idle speed (1800 RPM or so).
(06-19-2020, 02:34 PM)Jeff K Wrote: You can check VAM volts by tapping into the BK/W and W/BK wires at the 4 terminal VAM connector. With throttle closed you want the volts under .5 V. If much above that you can get high idle. You can adjust this by removing the 1/2" or so diameter plug on the top output (to turbo) side of the VAM. Drill a hole maybe 1/4" deep in the plug, screw in a sheet metal screw and pull the plug out using a vise grip on the screw. Use a long Allen wrench (I forget the size..... maybe 3/16" or so) to adjust the bypass air, which in turn changes the closed throttle VAM output volts.
Thanks Jeff !!!
Can i charge the bat. with cables connected ?
What about a battery tender ?
Thanks in advance ..again.Sure do appreciate N A T O & all the info !!!!!!!!!!
mike
No problem charging the battery with the cables connected. I have done it many times with no issues, even on our newer OBDII junk with 10x as much electronics in them as the TC has.
Battery tenders / float chargers are a good idea for a car not driven much, especially if you live in a climate with COLD winters like I do. Harbor Freight has them for extremely reasonable prices. I dont drive my Tbirds at all in the winters here as the roads are encrusted with salt for 4 or 5 months a year. I do start them up every few weeks and let them run until up to temperature, jack up the rear with my floor jack and run the trannies thru the gears several times to keep the trannies and rear ends lubed up.
