Raging Roller
GaryS#2 Offline
I finally found one (had to buy whole head)roller cam!
Stuck it in last nite and my valve timing must be out.
I used the gear that came with the Ranger Cam.
Is that OK to do?
My car is running, but not much power and is popping slightly when I rev it(after I let off the gas)
Should I change timing sprockets or just retard or advance timing?
Thanxs anyone!
I'll be outside playing.
Grocery Getter/Rice Cooker.
The RR sprocket should be OK. Recheck the cam timing and then the ignition timing
and jack rails.
GaryS#2 Offline
[QUOTE]Originally posted by Pete D:
[B]The RR sprocket should be OK. Recheck the cam timing and then the ignition timing
Hey Pete, I just ckecked the cam timing .I tried retarding it 1 tooth and really screwed something up.Would'nt run at all, so back to TDC.Still would'nt run.
Ignition timing should not have changed rite?
I'm really starting to wish I had left stock cam and running the way it was.
L.G.E.A "leave good enough alone" eh!
Dan E Offline
Gary, are you sure you didn't get the Aux Sprocket/Dist off 180 deg's ???
Dan Eaves
88TC 5spd, Shortblock with Crower 5.5" Sportsman Rods and Short Wiseco Pistons bored .030" Over, Ported Head with Polished Combustion Chambers, Gutted & Polished Upper, Ported & Polished Lower, Polished T/B, Ported E6, SVO T3 Turbo, 3" DP w/No Cat, RR Cam, Adjustable Cam Sprocket, K&N in Fenderwell, Gillis Boost Valve, Centerforce I Clutch, Removed A/C, Polished Wheels, Polished Valve Cover, Polished Crank and W/P Pullies, and the DAMN Heater Core is new too !
[This message has been edited by Dan E (edited 06-22-2001).]
Dan Eaves
GaryS#2 Offline
[QUOTE]Originally posted by Dan E:
[B]Gary, are you sure you didn't get the Aux Sprocket/Dist off 180 deg's ???
Feeew!
Am I tired.I got it figured out.That dist sprocket sure can make a difference eh?
I tweaked my timing by ear and the engine came to life once again.
Makes me wonder what an adj cam gear could do for accurate valve timing?
Tomorrow (today) I'll stick a lite on it and set it rite.
Then I can post the results of my RAGING ROLLER.
Maybe I'll piss off some of those guy's on the other board.LOL
DennySweet Offline
Gary Uhh Most of us are on the other boards!
88TC,87TC,88Mustang,86S-10,82Toyota,2-88S-10Blazers,56 Merc
88TC,87TC,,86S-10,82Toyota 4WD,3-88S-10Blazers.
It is almost a given that the distributor sprocket will turn a little when ever cam timing is adjusted. Checking/resetting the ignition timing should be considered part of the procedure.
and jack rails.
GaryS#2 Offline
[B]It is almost a given that the distributor sprocket will turn a little when ever cam timing is adjusted.
Ya, I guess.
So what happens with a distributorless ignition like my 95 Ranger?
I'm almost relcutant to do a belt on it now.
For Denny;I realize most of you are over there too, but these guy's here don't get pissed over something as trivial as cam's on this board.
