Radio Question
ES TC NUT Offline
I have the original am/fm/cassette radio in my 88TC and I can barely see what station it is on regardless if the lights are on or not. Is there a bulb in the radio that I can change or are they all this way?
88lxr4ti Offline
There is a light behind the diplay.But to replace it you'll have to solder in a new one.Try radio shack for the right one.
I think it's just simpler to replace the radio.Maybe someone here has a spare.
TCx2 Offline
Ah.. I think the bulb is plug in if I remember correctly. I know it was in my 88 Bronco. Seems I also changed it in my 88 TC.
Bulbs are hard to come by tho. I got my last ones at Ford. A lot cheaper than a whole radio.
Kevin
TCx2
88 White TC, 5spd, Loaded
88 Black TC, 5spd, Base
87 LtBlue TC, 5spd,Loaded
Kevin
TCx2
TurboCoupe50 Offline
TCx2 is correct it just plugs in. The bulb is #37, any good auto parts should have it. To replace it, remove the radio, then the top cover. The bulb is in a socket directly behind the display. Twist the socket to remove it.
Two 1988 Turbo Coupes ..... yea one of em has a 5.0 And runs 13.3s
1988 Turbo Coupe331 AOD
1972 Comet GT
Jeff K Online
Back when I had stock Ford head units in my cars, I usually just cut the connector off, and get a 12V "grain of wheat" bulb from Radio Shack for $.89, which has wire leads. I solder the bulb leads to the radio leads, stick the bulb in the hole, and secure it with a dab or RTV.
Noname
Guest
Jeff> Sounds like an awful lot of work to save a dollar or so.
If I remember correctly I just pulled a bulb out of a spare system sentry panel and threw it in the radio. They should be the same size bulb.
Yes, your Camaro just got spanked by a 4cyl!
Unless you're the lead dog, the view never changes.
