GoodSamaritan
Sep 2002
Lawrenceburg Ky USA
Could radiator be used as an intercooler?
as long as the boost was kept below 15lbs?
Any reason why it wouldnt be a good idea?
Bryan
Red_LX
Dec 2002
Morgantown, WV
I would say it wouldn't work because radiators probably wouldn't hold up to that much pressure, and I don't know if air would flow through them as well as water does.
Garrett Hunt
Moderator, 2.3L & Turbos Forum @ forums.stangnet.com
'87 Thunderbird Turbo Coupe
Windage tray, crank scraper, P&P head, RR, ARP head studs, P&P intakes, 60mm TB, Accel AFPR, Bob's log, T3, big FMIC, blow-thru VAM, Forge BOV, 3" exhaust, UPR shifter, gauges, etc.
My Turbo Coupe
SteveX82
Toms River, New Jersey
I'm sure the usual 1" inlet / outlet wouldn't be too great for flow, either. Besides, a decent intercooler can be had for $50 or less, thereby eliminating cost as an issue.
natmac3
Mar 2002
Aberdeen, MD
Sure it'll work.
You also might try using a radiator cap as a blow off valve, and an EGR as an external wastegate.
![[Image: smile.gif]](https://images.weserv.nl/?url=natoubb.turboford.org%2Fsmile.gif) I'm just kidding, honestly, the physics/functions seem similar but it'd never work.
1987tc
Might work, but not very well. A typical IC is an air to air heat exchanger, and a radiator is a water to air heat exchanger. Water and air have WAY different thermodynamic properties, so a radiator is designed way different than a IC.
2ManyRecklesses
May 2002
chesapeake va usa
.. i also don't think a radiator would flow the air NEARLY as well as an actual intercooler..
"It takes two to lie, Marge. One to lie, and one to listen" - Homer Simpson.. my hero
