KentCT88TC
Oct 2006
Beacon Falls, Connecticut
My TC is under the cover for the winter, but if we get some warm Saturdays, I would love to clean off the grounding points. I get a shock every time I get out of the car. This link is broken:
3. Cleaning grounds is never a bad idea. There is a list of grounds here: http://www.turbotbird.com/FAQpage/FAQpag...0Locations
This is for 87-88s
Anyone have a list of grounding points? Thanks -Kent
-KentCT
-'88 Turbo Coupe, K&N, Gillis valve @18 lbs., 2.5 " exhaust.
-2000 Mustang GT 373 gears, Diablo computer chip, cold air intake, Typhoon intake manifold.
-2001 Jeep SE 2.5, AEM cold air intake, Gates headers & exhaust, throttle body spacer, Jet Stage 2 chip
Try this: http://turbotbird.com/faqs/#Electrical%2...0Locations
If you go into the FAQs (link at the right side of this page, I think those links work OK.
KentCT88TC
Oct 2006
Pete, Thanks!
-KentCT
Always a good idea to keep grounding points clean and tight, but that wont help with the getting a shock when getting out of the car. Thats just static electricity generated between the seats and your clothes when you slide out of the seat, just like walking across a carpet and getting a shock from a door knob in cold low humidity weather.
goldwing
Aug 2009
North Carolina
Jeff K Wrote:cold low humidity weather. Ditto
I work around a lot of electronics and we have to adjust the humidity to prevent electrical component damage.
As a young boy I remember the adults would some times have a pot of water on the fire place during the winter. I never understood why until I got older.
T.C:87 5 speed
w60
Dec 2011
Birmingham, AL
w60
I'll swear up and down that I get shocks for more reasons than static electricity. Even in summer with 90% humidity, I'll get a pretty good bite if I touch the door frame sliding out. I've thought about checking grounds for quite a while but sometimes I'm just to lazy, and now with deer season in full swing I'm to busy!
You can not get any kind of shock off a 12 volt system, period. IEEE has, based on extensive testing, defined any DC voltage below 48 V DC as 100% safe, meaning no possibility of any shock hazard even under the worst condition. Any shocks from a car are due to static electricity (assuming you dont grab a bad plug wire on a running engine!!). The car is insulated from the ground by the tires. Even the friction between the car body and the air while driving develops a static charge on the car body. Back in the old days, people used to bolt somewhat conductive flexible strips to the car frame at the rear that would drag on the ground to discharge the static built up on car to avoid shocks.
