Quick Question, Ignition Switch
martin0660 Offline
Quick Question, Is the the only thing needed when replacing the ignition switch?
http://www.rockauto.com/ref/Motorcraft/D...w-2474.gif
They have it listed at ~$7, for a Motorcraft part, and it confused me [Image: smile.gif]
Bob Myers
mjbtbrd Offline
I got one from them a few months ago.........it even came with new screws.....you do need a tamper proof torx bit for the screws though....that should be all you need unless there is an issue such as the connector being burnt
Bob, just "dremel" some slots in the existing screws and then use a regular screw driver on them
martin0660 Offline
I loosened the covers, and took a peek at it later today, and the screws have a slot slightly offset from the center, and a protrusion in a hole in the center. I assume to make it tamper proof.
Have dremel, will operate [Image: smile.gif], just need to get the switch here.
Bob Myers
