Quick question?
1fasttc Offline
which fuse is for exterior lighting? when i drive at night my lights flicker on and off...which fuse can this be?
How fasat do they go on and off?
See http://natomessageboard.com/ultimatebb.p...803#000002
The headlights are on a circuit breaker as mentioned by Jeff K in the post above. They are not on a fuse
1fasttc Offline
they flicker on and off pretty fast...and i have to mess around with the light switch so they can stay on...and when i push the light switch ON position(as if they worked properly) only my head lights turn ON and my dash and rear lights dont light up.
Check your email for fuse locations
5speedthunderchicken Offline
Hey Pete could you send me that sheet were the fuse's are located?
Dan
88 T-Bird pretty much all STOCK! (dont have much money to put in her)
1fasttc Offline
Thanks for everything!much appreciated
Dan, check your email.
When you say "exterior lighting, what exactly do you mean? Headlights run thru a self resetting circuit breaker inside the headlight switch, marker lamps, tail lamps are powered thru a fuse.
Got it Pete. Thanks!
Dan
1fasttc Offline
Thanks..got it fixed! well i checked my injectors and the o rings were fine,but i think the tip of the #1 injector was broken...do i have to buy the tip sepretly or the whole injector.
