question on rear brake rotors
Turbo Coupe Offline
before anyone says anything, i searched A LOT but havent found a straight answer on this. im interested in swapping to five lug. the front is no problem but i have a question on the rears, i know i can use a SN95 axles or have my stockers redrilled, but im unsure what to do about rotors, i know the stock ones can be redrilled and machined to fit the hub on the sn95 axles or just redrilled along with the stock axles. but could i just use SVO rear brake rotors or stock sn95 rotors? if not why?
1987 Turbo Coupe 5 Speed - 14.528 @ 90.50
-Blown IHI Mod
-93 Style Black Cobra Wheels w/ 255 45 17s
-2.25 Turn Cobra Rack
-Aeromotive Regulator
-Intercooler Fan
-6AL Box & Two Step
-Cone Mounted on VAM
-BCS Disconnected, 17-18 psi
-Weight Reduction
3318lb Race Weight
WISH I HAD MY OLD CAR AGAIN!
R.I.P
1987 Turbo Coupe 5 Speed - 1.77 60ft, 8.811 @ 76.76 1/8th
-Draglites With Hoosier QTPs & 165Rs
-Weight Reduction
29xxlb Race Weight w/Driver
tps87turbo Offline
You can use the axles from an LSC to go 5 lug. Not sure if they will match what you are putting up front as you did not say what thay are.
Tony Sceia -
HIS Red 88 TC
Turbo Coupe Offline
ill be using SVO rotors up front, i read that they will work with the stock calipers.
anyone else know if LSC stuff will work?
R.I.P
-Weight Reduction
cougarman Offline
Yes the LSC brakes will work. The early, pre '92, are the same as the SVO. [Image: biggrin.gif]
Feel the Thunder !!
Turbo Coupe Offline
awesome! so you didnt have to change your calipers?
R.I.P
-Weight Reduction
cougarman Offline
Yes, you have to use the entire LSC setup, shafts, brackets, calipers and rotors. [Image: biggrin.gif]
Feel the Thunder !!
AerobirdMotorsports Offline
Banned
You can use TC calipers with LSC rotors, they even use the same size pad. The LSC's calipers have a bigger piston for better braking though, and are actually cheaper to buy new ones at any NAPA.
Michael Pinto
www.aerobirdmotorsports.com
1983 Silver/Raven cloth, 5Spd, wing windows, 93K
1988 Med Red/Red leather 5Spd, moonroof, all options, .030 over forged Sealed Power Pistons, ARP bolts & studs, hi-vol oil pump, balanced & blueprinted, big hollow roller cam, ported intakes, ported E6, Optima, open exhaust, K&N, Kirban AFPR, BBK 255, Cruzin Injectors, AM IC hoses, Dyno-Mod Ignition System, Royal Purple, .63 A/R water cooled T3...
1987 Code 33 Silver-Blue/Charcoal cloth, will *soon* be a race car
1988 White/Charcoal cloth auto, g/f's car, HL mod, Clarion CD/Stereo
1988 Shadow Blue/Blue cloth 5Spd, parts car
1988 Cougar LS Med Red/Red cloth, 5.0/auto, moonroof
1992 Dk Green SHO 5Spd, feature car, 13.37 @104, for sale
Do you think I have enough yet???
Turbo Coupe Offline
well thats good news, so if i get LSC rotors i can reuse my orignal calipers and pads with no issue then correct? sorry to keep asking but i just dont want to run into a problem.
R.I.P
-Weight Reduction
Rod K Offline
Can I use the turbocoupe calipers with SN95 rotors and axles? The reason I ask is that I have new TC calipers, brake lines and pads on the rear. I think all that was over $200 and I would like to use it.
Rod Kiser, '88TC, 5 speed, 5 lug, Cobra 13" front brakes, Mark VII 11 1/4" rear disc brakes, PiMP'n, Bullit wheels, ATR 3" exhaust, Aluminum driveshaft, EDIS, 60 LB injectors, gutted upper & ported lower. NATO Member
