TURBOCOUPESRULE1325
Dec 2004
Brooksville, FL
to sell or not to sell that is the question
i was thinking about selling my 87 TC but now im having diff thoughs all she needs is tlc and a pro to look at it but i cant find any one to help in my area what should i do really??? i love this car
87 TC sandle for now , just fixing the beast up, gutted cat, needs drivers side window motor, pass. side mirror(just the glass), stock exhaust from cat-back, drivers side tail light, wireing work....
What is the problem with it?
TURBOCOUPESRULE1325
Dec 2004
Brooksville, FL
well it just doesnt run nice(used to run ok, but now wont go over 3500 rpm, fuel pump is knew all is tuned up except cap and rotor, i guess my intake may be leaking ill need a new gasket set) and i need all the wiring redone , i also need my gauges to work
Quote:now wont go over 3500 rpm,
Did you? :
Change the fuel filter?
Check the cam timing and then the ignition timing?
Check fuel pressure?
Check/change if needed, the air filter?
Quote:i guess my intake may be leaking ill need a new gasket set)
Can you hear a leak or did you test for it in some way? Is idle vacuum low?
TURBOCOUPESRULE1325
Dec 2004
Brooksville, FL
and i want it to last me a long time and be reliable
TURBOCOUPESRULE1325
Dec 2004
Brooksville, FL
fuel filter is changed, havent checked timing, or fuel pressure, air filter is new, cant hear any air leaks atleast
svo_thunderchicken
Jul 2005
Kingsport, TN.
its your timming, mine did same thing, found out someone set timming to 10 deg atdc instead of btdc... these cars are very senstive to timming, Look on our tech article section on adjusting ignition timming first....
http://www.turbotbird.com/FAQpage/FAQpag...ust_Timing
Matt S
Mountlake Terrace, WA
To sell or not to sell this car is more of the question "do I want to do the work since I have pro's here on NATO to help me, or do I trust a mechanic to work on a car he/she has never seen before"?
Unless you take the car to a "pro" that *HAS* an SVO or TC.. (not "heard of it") they are not a pro so far as this car is concerned IMHO. Just trying to find someone with a smoker for leak testing netted me many mechanics who would have bet their shop that Ford **NEVER** put a 4 cylinder in a Tbird, actually arguing with me on the phone that I can't see that supercharged V6 for the trees.
Good mechanics out there, but this just isn't your run of the mill car.
We can tell you everything you need to know, but if you just aren't into figuring it out (which is totally fine) then a fine member of this board will be happy to give it a TLC home so you can purchase something worry free. Just let us have first dibs  . Or maybe you'd rather pay a member to go to your house instead of a mechanic?
I'm ribbing you mostly...but the fact remains that this is (generally) not a car to take to a mechanic. BTDT.
Sold it  *
Ryan H
Oct 2004
Panama City, FL
Same. Gotten shafted more than once. Now I do everything myself.
one of two problem cause that fuel pressure regulater or vam !
