Question about front brakes
Ohio88TC Offline
I am planning on changing my front brakes today and was wondering what is needed to change them. Are there any special torx bolts on them to get them out or no. I remember my 85 having them but does the 88TC and do i have to do special to the front ones when i put it back.
Dragging this out of the cobwebs of my memory, but I think the only "special" tool you need is a Torx T45 bit.
Ohio88TC Offline
Thanks
Noname
Unregistered
Actually 87-88 TC brakes do not need any special tools to take them apart unles syou want to buy a special tool to turn the rear calipers back in. Most of the guys use needle nose pliers for thsi though. If I remembe correctly it is a 17mm socket to take the front pins out and a 1/2" or 13mm one to take the bolts out of the back.
Yes, your Camaro just got spanked by a 4cyl!
Ohio88TC Offline
Thanks James I knew about the torx on the earlier birds but didn't know on the 87-88TC's
I have already done the rear and i use a pair of pliers to turn the piston back in.
