question about dropping tranny
elktonracefan Offline
i have a 5 speed and need to drop tranny, noticed a leak probably rear seal. my question is, is there anything else i should do while i have it out just so i don't have to drop it again in the near future?
3bird Offline
Fresh tranny fluid, and personally I'd sure put a new clutch in while the transmission is out.
With almost any oil leak, the oil ends up in the area where a rear seal leak would also be.
Make sure that the leak isn't originating somewhere else
PetzJC Offline
If the driveshaft U-joints have not been replaced in a while, might as well do those while the driveshaft is out.....
88 Silver T/C, original owner, 258,000 miles.
Loaded with everything except leather & auto trans.
Short block & turbo original/untouched.
Polyurethane bushings throughout, Goodyear GT-HR 235/55R16's.
Rodger Offline
If you also pull the clutch and flywheel, be sure to change the rear main seal.
Kev Offline
I'd definitely put in a new clutch fork and throw-out bearing to get rid of, or prevent, the cricket sound that these cars are well known for.
Kev
1988 TC 5spd
tlswart Offline
Check for end shaft play on your tail piece of the tranny. If you have play then replace the seal and bushing. Take the drive shaft to a tranny shop and have the drive shaft balanced if you do have play. Cost is 16 for seal and bushing and 24 for balance. Money well spent and easy to do.
To remove simply unbolt tail piece. Use RTV on clean surfaces to replace.
Terry: 88TC, 5spd, Gillis valve.
