Scheetz87
Oct 2006
Carthage,il
I have recnetly installed some QA1 coil-over struts and was planing to put some Cobra R rims (17x9in) But the problem is i have some stock 16" snowflake rims on now and with the coil-overs in the front are about a centimeter from rubbing the tire, So basically i wanna know if anyone has some 17x9 rims with QA1 coil-over struts and how well do they fit?or do they at all?
JohnL
Jul 2005
Madison Heights, VA, USA
I have no direct experience, but consider this: A larger diameter wheel gives you more clearance, but you will also be 2" wider than the snowflake. It's really going to come down to the difference in width AND backspacing. Backspacing is what you want to know, if the backspacing is anything greater than "about a centimeter" more than the snowflakes then it will rub.
John Lewis
88 TC, 87 XR, 84 SVO
Scheetz87
Oct 2006
Carthage,il
No one has these Qa1's installed on a TC? cmon
