Q: Retaining e-brake with SN95 brakes/5 lug
goldwing Offline
As far as I know there are two options for 5 lug rear with disc brakes.
1st) is machining the stock T.C rear disc to 5 lug.
2nd)Use SN95 Mustang rear components.
I've read here on turbotbird that if I use the SN95 parts that I will loose my E-brake.
However,on Cool Cats it dosen't mention the lost of the E-brake. It actually says that the SN95 Mustangs use a T.C e-brake set up. It seems like Cool Cats is implying its a direct fit.
Take a look at Cool Cats here.
http://www.coolcats.net/tech/advanced/4to5lug.html
So,...anyone done the swap and retained the e-brake? Or anyone have any useful info to help in this area?
THANKS
T.C:87 5 speed
BJL Offline
Moderator
in about 3 weeks i will be able to tell you yes or now. it looks you can.
i bought a tc rear with sn95 brakes on it. and the car i got it from it was hooked up. i bought new cables for a tc and plan on installing them with the new rear. i will let you know if and how well they work. i don't see why they wouldn't. the calipers is practically the same jut not was wide (rotors not being vented the rotor is thinner).
Brian J Larkin
88TC 328,000 miles
89 Cougar XR7 3.8SC Auto
95 Ranger Splash 3.0 auto
teal95 Offline
The late Mark VII ('91+) used the same caliper as the TC and was 5 lug. Any chance those rotors have the correct dimensions to drop in? Then you would just use the SN95 Mustang rear axles.
steve
'83 & '84 GT turbo EEC-Tuner
'85.5 & '86 SVO twEECer
2x '87 & '88 TC QuarterHorse
'93 LX 5.0 notch Moates chips
3x '95 & '96 GT
goldwing Offline
I've been reading for about 4hrs straight. I found this on Turboford.net. I'm still not done but I'm about to go to bed.
Anyway, notice the 5th post down from Rod K.
http://forum.turboford.org/cgi-bin/ultim...2;t=049786
Good night
Edit: Nevermind the Mark VII rear parts since the axles are little longer. I plan on useing 10.5 rear wheels but hey atleast his e-brake works.
Brain fried, time to shut down.
T.C:87 5 speed
