Putting on Bird decals?
23027 Offline
So what would be the best substance to use in sticking my chrome T-Bird decal back on my tail light?
I tried to use 5-Minute Epoxy all it did was leave a sticky mess to clean up. Didn't hold at all. It was supposed to adhere to plastic surfaces too..
Thanks
87 Turbo Coupe
BJL Offline
Moderator
try 3m double sided tape, it kinda like a thick foam tape, it meant for emblems and trim. it holds my body side moldings on my TC with no problems
Brian J Larkin
88TC 328,000 miles
89 Cougar XR7 3.8SC Auto
95 Ranger Splash 3.0 auto
23027 Offline
Yeah the side moldings it will work good..
But it will stick out if I use that double sided tape..
Not good
87 Turbo Coupe
Joe F Offline
They also make a very thin (almost like regular scotch tape) double sided product that works well if both surfaces are flat. I'm pretty sure 3M has it.
tc² Offline
I stuck my Turbo Coupe emblems on the 3M double sided tape and traced around it with an exacto knife. After I pulled the excess tape off, I went around the whole thing with a sharpie so you couldn't see any white. Looks factory.
Beau Offline
i used a very small amount of two part opoxy on my wifes car with good results.
Beau
-1988 Turbo coupe, 5 speed, Homemade boost controller, K&N cold air kit, By-pass-valve
-1988 mercury Cougar XR-7, 5.0
23027 Offline
Awesome.. I think i'll go with the double sided tape.
Very helpful.. Thanks boys
87 Turbo Coupe
