lcdearman
Dec 2007
Taylor, Texas
The compression was:
#1 - 80
#2 - 80
#3 - 120
#4 - 120
Here are some pictures:
#1 cylinder to the left, #2 centered. Note dark area between them.
http://natomessageboard.com/uploads/0000...lock_1.JPG
Here is a picture of the head gasket between #1 and #2. Note dark stripe towards bottom.
http://natomessageboard.com/uploads/0000...sket_1.JPG
There is a lot of carbon on #1 piston, the others look fine. The valves are all whitish grey. Maybe running lean?
Did I just catch this very early in the gasket blowing process? The engine was a little down on power and Friday the idle was a little rough after warmup. With 25 psi air going into #1 I could hear a little air in #2 but it wasn't horrible...
Thanks,
Clay
88 TC - Daily driver, maroon, 5 spd, K&N, pony wheels
81 El Camino - 305/TH350, working on MS TBI/spark conversion
tr_guy79
Jan 2004
SE PA (DELCO), USA
Definitely looks like it was leaking between 1 and 2 on the under side of the gasket. Did you check the head for flatness?
Be sure to check th block for flatness in that area also.
lcdearman
Dec 2007
Taylor, Texas
I'm gonna borrow some machinist's flats tomorrow and check it out.
TurboCoupe50
Chesapeake, Va
The gasket wasn't leaking on the side pictured, was that the head or block side??? There apparently is evidence of leakage on the block surface...
lcdearman
Dec 2007
Taylor, Texas
That was the block side of the gasket. The head was clean, no signs of anything.
lcdearman
Dec 2007
Taylor, Texas
Well, the deck and head check out so I am just going to reassemble it with a new gasket and head bolts. It should be just fine...
RDOG
Jun 2001
Ontario. California U.S.A.
Did you pull the valves out of head, to see if there is a crack between the seats? Since you have the head off, I would go ahead and change the seals for increased assurance? Plus those pistons look like seals are going bad too. Lots of black caked up carbon. Was the car smoking?
lcdearman
Dec 2007
Taylor, Texas
I have not pulled the valves. This engine does not smoke either. #1 cylinder had carbon, the rest look pretty good to me for 211,000 miles. I have had smoking engines before and the plugs always showed signs. The plug for #1 was actually too white, the rest looked good. No signs of oil or carbon. That was why I did the compression test in the first place. The carbon really wasn't much and wasn't wet or caked like I have seen in oil burning engines in the past. It came off very easily.
The only issues I had were the car started running a little rough at idle on my way home from work on a Friday, Saturday I did the compression and "leakdown" test and found #1 and #2 low on compression and air from #1 was coming out the #2 spark plug hole.
lcdearman
Dec 2007
Taylor, Texas
RDOG, I see you are in Fontana. Are you a mechanic and did you have a TC up for sale a little while back, a maroon one? I ask because my son lives out in LA and met somebody at union station (I think that was where it was) to look at an '88 TC. I think it was at the end of last year.
