I finally got the boost problem sort of fixed. Seem to have been some film or a particle in th eboost valve limiting me to about 13 psi. I may need a new ball but for now I've got it limited to 15 till I get to drive it some. Seems that 15 " vacuum is about normal for the A-237 camshaft. I'll start playing with the adjustable cam sprocket this week. Seem a lot of guys have found 4* advance a good setting. I've detected some hints of surging, probably the same thing Dan ran into. Soon as I run the tank empty I'll drop a 190 Walbro in it and get an adjustable FPR in the system. I can really feel a need for a bypass valve now so I'm going to have to figure out how to plumb that in.
and jack rails.
mmedic50
May 2001
Garrett, Indiana 46738
Where can you find an address for the Walbro fuel pump? Who sells them?
1988 TC 5 speed, Dark Blue
Build date 5/88.
140 mph Ford Motorsport Speedometer
Tripminder
Walbro 255 Fuel Pump
Kirban Adj. Fuel Pressure Regulator
K&N Air Filter
Gillis Boost Control Valve
New rebuild- .030 over pistons.
SS valves(1.89/1.59).
Center Force Stage II clutch.
ARP head studs.
Crane roller cam .450 lift.
Gutted upper and ported lower intake.
Ceramic coated and ported E6 exhaust.
see the place Dan mentioned:
htp://www.jdsperformance.com
and jack rails.
GaryS#2
May 2001
B.C. Canada
Project update?
I thought you had your bird all running fine?
Does anyone have a T bird finished and running?....lol
Grocery Getter/Rice Cooker.
SteveX82
Toms River, New Jersey
haha, i couldn't help but laugh at that. sorry, it's a tad bit late and i'm feeling pretty weird and tired. you know how that is....
GaryS#2, the words T-bird and finished are mutually exclusive (lol)
Steve, after I get my foot out of my mouth, I'll probably need two new ones, one for the boost valve and one to replace the one that has been twisted out of shape by this project, hehe
and jack rails.
BIG VAM
May 2001
houston, tx, usa
When do I stop fixing the "normal" stuff & start fixing the "cool" things? [Image: smile.gif]
Needing a 2nd gear synchro....
Needing a heater core (grrrrrrr)
Needing to put in struts......
Etc, etc, etc, etc,
No trees were harmed in the posting of this message, but several hundred thousand electrons were terribly inconvenienced...
DennySweet
Centreville,Michigan
Never!!!!! Ask Pete and Dan
88TC,87TC,88Mustang,86S-10,82Toyota,2-88S-10Blazers,56 Merc
88TC,87TC,,86S-10,82Toyota 4WD,3-88S-10Blazers.
