TurboBays
Nov 2002
Sophia,WV USA
Well when I took my TC out for a little spin in the good weather yesterday the check engine light would come on, and when it did the engine would stall?? I check and the only thing that I could find was it was low on anti-freze. Also like in first gear before I get to 2000rpm my car will rock back and forth like an old mucle car with a finaly tuned big block. And if I get off the gas and let it coast you can watch the gear shift just rock back and forth and you can feel it in the car. But as soon as you get back on the gas it quits. What could this be. Thanks for the help. (sorry for such a long post)
Dan E
Greensboro, NC
First things:
Run the EEC Codes.
Check your Fuel Pressure.
Dan Eaves
Dan Eaves
