turboedthunderchicken
Nov 2008
waverly,oh
anyone ever have a premium sound amp go bad?what did it do?i think mine did very little sound and only on certain speakers then sometimes its works great
1988 turbocoupe(boost controler,15psi,2 1/2in custom exhaust,4.10 gears not sure on rest
1978 ford fairmont futura 4.6cobra motor
1980 ford fairmont sedan 302 with juice 10.8 at 130mph
TCx2
Sierra Vista, Arizona
Any time I've experienced what you are describing it was traced to the volume or fader controls. If you turn those knobs around aggressively the sound would come back. I would spray contact cleaner in them (have to remove and disassemble both radio and EQ) and it would be fine for awhile.
Kevin
TCx2
Nov 2008
waverly,oh
figures i when and bought a complete sony cd player with new speakers and all and to day the factory radio played great!
FLSTCI71
Apr 2004
Rochester, MN
Well, if you end up needing a factory amp, just let us know. We've got an extra one around we could send to you. Either way, good luck.
1987 Turbo Coupe - Son's car
1987 Super Coupe - Son's project car
1934 Ford - My project car
Nov 2008
waverly,oh
thanks but found out today that its in the factory EQ started acting up so i pussed really hard beside the left/right balance knob and it took right back off workin great but it gave me fits all day long!
so i dont know wether to put in the sony system or find a good EQ any recomendations?
HOODBIRD
Mar 2008
WASHINGTON, DC
I think you should upgrade unless u wana stay stock. Alot of new radio's have eq's and sound features in them.
New speakers will also help alot.
I have a flipout tv with all new speakers.
I have the 6 speaker setup with a custom built sub box in the upper deck of the trunk were the spare and jack would be.
86tc 5speed k&n, gfb boost controller, autometer gauges, tripminder, fmic, and upgrading as fast as possible
TCx2
You've got nothing to lose to take the EQ out, take it apart and soak the fader control (I assume that is what you meant, balance is on the radio, fade is on the EQ)with contact cleaner. I've had success with that in the past. If it doesn't work, well you've got the EQ out of the way to do whatever you want to do. : )
Kevin
TCx2
Ford premium sound sound in the 80s was horrible. Even a cheap head unit would run circles around it. Later Ford sound systems improved alot... the Mach audio system in my 05 Taurus Duratec SEL DD is really great..... the only car I ever bought that I didnt replace the stereo within a week of buying it.
If you really want a "prem sound" amp, I think I may have a few laying around in one of my junk piles.
