So my firm light has been blinking while in auto mode since I bought the car. I found how to check the codes in the FAQ. –Put the jumper on, started car, removed. The light went out then repeatedly flashed twice - Same as it was flashing when driving in auto mode. So I guess the fault is the back right actuator circuit. Another thing I noticed is when I switch the car into run mode I hear three clunks or like someone tapping on glass coming from the back right.
I’m hoping someone here could help put me in the right direction to find out what exactly is the problem and how to correct it. If anyone has got a bit of helpful info, some links or suggested reading I’d really appreciate it. I’m thinking I might just try replacing the actuator with one from my parts car first. That would be a nicer fix then trouble shooting the electrical.
BTW- Got my car out of storage for the first day of the season yester day! Pretty pumped about it.. except $1.30/L for 92 octane...
Thanks
Thanks
1988 Turbocoupe
K&N, Gillis Valve, ported E6 Otherwise stock.
