ok my PRC light is on, exactly what part is it that lowers and raises the car?? and does any one have one for sale for less than $800?
thanks,
david
Looking for the 5.0, airplane, turbocoupe, and GIRL of my dreams!!!
Wings are for planes!!! (I would know I fly them!)
RDOG
Jun 2001
Ontario. California U.S.A.
If you are broke, like I always am, just disconnect them and ask mfor the stock shocks and struts. They work fine. I went to Pep Boys and got the full set for less than it cost me to get 1 PRC. Than just reach behind the seat and unplug the prc system.
thanks,
david
What exactly do you mean by "on"? Is it flashing with a regualar pattern, indicating a fault code? If the light is just on all the time, even if the switch is in the AUTO position, you might have a bad FIRM/AUTO switch. The PRC doesnt lower and raise the car, it just alters the damping rate of the shocks / struts. Even if there is a fault in the PRC system, the shocks / struts may still be good.... the electronic PRC system doesnt know anything about the shape the shocks are in. IMO, the PRC system is one of the things that make these cars unique, and is worth fixing if the problem is electrical, which can often be fixed with little $$$ outlay.
Black87TC
Mar 2002
Canada, West Coast
There's a good trouble shooting guide in the FAQ section here that'll prolly help you with your decision.
HTH
Jim
'87 TurboCoupe 5-spd. Lookin' to make it faster...
11 Second '87 Grand National
well i was actually just curious, I actually have shocks and struts from a 01' mustang that I am about to put on. Thanks guys!!!
later,
david
DrPhang
Petersburg, Virginia,
Ummmmm my PRC was broke.....I just looked in the FAQ and used the number of blinks by the light to determin which actuator was bad, went to the JY and fixed my PRC for the grand sum of $3 dollars. It makes a bigg diff in the way the car handles
