What is the procedure to remove the power steering pump? It appears the pulley has to come off to access the bolts holding the pump to the mounting bracket? If so, how do you reinstall the pulley after the pump is reinstalled (BFH - just joking!)? Any help will be greatly appreciated.
Ken Humphrey
88TC, Black/Raven, FMIC, 130 amp alternator, MSD ignition, 40Bob manifold with 3" downpipe and Magnaflow 2 1/2" duals, trunk battery with disconnect, CHE rear control arms, Koni Sport shocks, MM front coil-overs and caster/camber plates.
