Uncle Fester
Aug 2006
Double Oak TX
Getting ready to install a Stinger FMIC and have a technical question regarding the power steering fluid cooling loop. I need to keep the A/C (Texas summers) so I have to relocate the PS cooling loop. I thought about installing a radiator with built in transmission cooling and routing the PS fluid thru it. Were I to do that, would I be cooling the fluid or heating it? ie, under normal operation is the PS fluid cooler or hotter than the radiator coolant?
Tony
fletchusmc
1988 Auto daily driver
1988 Manual daily driver
1987 parts car
Thats what im dealing with here at the moment the fan sticks out of the shroud slighty and comes in contact with the intercooler piping and long behold its the ac lines in the way and i really dont want to loose the ac
88 T-bird stinger fmic/cold air intake/t3t4/stinger oil feed line/3 inch full exhaust to dauls/super coupe throttle body
Get a power fluid to air power steering cooler on Ebay, install it in front of the radiator and be done with it.
Uncle Fester
Aug 2006
Double Oak TX
(06-07-2019, 09:14 PM)Jeff K Wrote: Get a power fluid to air power steering cooler on Ebay, install it in front of the radiator and be done with it.
That seems to be the consensus all across the internet. Thanks for the quick response Jeff.
fletchusmc
1987 parts car
(06-08-2019, 12:27 AM)Uncle Fester Wrote: (06-07-2019, 09:14 PM)Jeff K Wrote: Get a power fluid to air power steering cooler on Ebay, install it in front of the radiator and be done with it.
Uncle fester what did you do about the ac lines ? And clearing those?
Uncle Fester
Aug 2006
Double Oak TX
(06-08-2019, 01:41 AM)88turbobird5 Wrote: (06-08-2019, 12:27 AM)Uncle Fester Wrote: (06-07-2019, 09:14 PM)Jeff K Wrote: Get a power fluid to air power steering cooler on Ebay, install it in front of the radiator and be done with it.
Uncle fester what did you do about the ac lines ? And clearing those? Not quite there yet, I'm doing an engine swap with a re-built engine and we will pull the old engine this coming week. From the initial mock up though they don't seem to be a problem. I'll take some photos when we start pulling and get the new engine in along with the FMIC installation.
fletchusmc
1987 parts car
