Flash
Nov 2007
Maryland
My battery works. The Car starts. I Lost Sunroof power. Power locks. Car makes wierd noise when key turned to just have the battery on. Clock out.Headlights and everything else work fine. Happened when I remounted the push button lights about the rear view mirror. There out too. They went out at the same time. I checked all fuses under dash. Everything is fine. What could it be. What fuse controls all of that.
Matt S
Mountlake Terrace, WA
Push button light about the rear view mirror? What's that?
What kind of weird noise are you talking about?
You pulled the fuses under the dash and ran a continuity test or just looked at them?
Sold it  *
Clock, power locks is on fuse #8. Other thinks on the same fuse are key warning, illuminated entry,
power outside mirrors, courtesy lamps, cluster memory and chime.
Moonroof is on fuse #14. Power windows are also on this fuse.
Quote:Push button light about the rear view mirror? What's that?
I think he means the map (reading lights) on a moon roof model. They are mounted near the rear view mirror.
Flash
Nov 2007
Maryland
all fuses are fine. What could of happened?
Look for something those circuits have in common, maybe a fuse link. I sent you the charge power distribution schematics which should help.
Nsw
Apr 2004
Vancouver, British Columbia. Canada
Nsw
pete would it be possible to send me those schematics too, im try to find some electrical gremlins of my own
Nsw, I'm sending the charge power stuff. If you are having a problem with some subsystem, let me know, I might have other related diagrams.
Nsw
Apr 2004
Nsw
thanks for the diagrams pete, might be a while before i get to work on the car though, seeing how we just got about a foot and a half of snow
