pederb
Feb 2004
Hollywood, CA
My PB stopped working the other day and is this a common problem on these? Any idea how to repair this or do I need to replace the whole thing?
-Peder Beckman-
Technical Director
American Iron Racing
-Peder Beckman-
Technical Director
By "stopped working" do yo mean the pedal got real hard and it takes a great deal of push to get the car to stop.
If that is it, then take a look here:
http://www.turbotbird.com/FAQPage/FAQpag..._Diagnosis
Relay part number: http://natomessageboard.com/Forum12/HTML/000054.html
pederb
Feb 2004
Hollywood, CA
Yes that is right.
Were is this relay located?
-Peder Beckman-
Technical Director
-Peder Beckman-
Technical Director
Under the black plastic cover immediately below the vacuum tree. There are 2 relays ther. I think you want the one toward the front of the car
jmthunderbirdturbo
Feb 2005
Ostrander, Ohio
wow, i didnt know they did that. mine just f**king runs the damn abs pump over and over untill the thing kills the battery over night. oh well. check your fluid too and maybe bleed the lines if the relay thing dont work.
1987 5.0 sport coupe, intake, exaust.
1987 tc, goldie, stock 5 spd.
1987 3.8, convertabird project car.
without disapointment, you cant appreciate victory, but victory would be nice every now and again.
pederb
Feb 2004
Hollywood, CA
Great!
Thxs
-Peder Beckman-
Technical Director
-Peder Beckman-
Technical Director
Ryan H
Oct 2004
Panama City, FL
The relay is probably sticking then [Image: smile.gif]
Ryan Harris
1988 TC 5 speed, all options including sunroof, Walbro 255 LPH HP, Star stage III, bypassed BCS and lots of love
Ryan is correct.... the ONLY way for the pump to run with the key off is if the relay is stuck shut. Replace the relay and your problems should be solved. If you get a new relay from Ford, I believe they call it an "anti-skid relay".
88 Turbo Coupe: Intake and exhaust mods, T3 turbo at 21 psi, forced air intercooler, water injection, bypass valve, Ranger roller cam, subframes, etc., etc.. // 86 Tbird 5.0 (original owner): intake, exhaust, valvetrain mods, 100 HP nitrous, ignition, gears, suspension, etc., etc.... // 91 Escort: Bone stock winter car // 04 Taurus Duratec (wifes car)
pederb
Feb 2004
Hollywood, CA
Well I replaced the relay but nothing, is there a fuse or circuit breaker for this? The relay was ticking very loud before it went dead.
-Peder Beckman-
Technical Director
-Peder Beckman-
Technical Director
JT
Few things to check:
1) There is a Tan/Yellow wire at the hydraulic relay. This circuit is hot at all times, and is feed through a fuse link. Make sure you see positive 12 volts at that wire.
2) Turn the Ignition Key ON, and check for positive 12 volts at the Grey/Yellow wire at the hydraulic relay. This circuit is feed from a fuse link as well, whenever the Ignition Key is ON
3) Pump the brake pedal several times with the ignition key off. Now check to see if the Pink/Light Blue wire at the hydraulic relay is getting a ground.
4) Check to ensure that the Grey wire at the hydraulic relay is getting a good, continuous, ground.
[This message has been edited by JT (edited 03-16-2005).]
