ABird
Mar 2011
Myerstown, PA
Antenna troubleshooting.pdf (Size: 309.67 KB / Downloads: 120)
From the 1988 Thunderbird/Cougar Electrical and Vacuum Troubleshooting Manual
AES
anasazi4st
Feb 2015
Phoenix, AZ
(01-29-2024, 09:33 PM)ABird Wrote: From the 1988 Thunderbird/Cougar Electrical and Vacuum Troubleshooting Manual
There is also a writeup in NATO FAQs about repairing the plastic toothed "cord" that powers the antenna to move up or down. After spending quite some time finding and purchasing a replacement, I decided to try that repair first before installing it.
That was more than 10 years ago...so that should give you some idea of how that went.
I've replaced the mast and that part wasn't hard but ever since I replaced it my radio won't pick up anything but the strongest signals, it's really annoying. Thankfully I use my bluetooth through my phone and the signal is fine to the current antenna.
